Autor Tema: Creator Ci40: The ultimate IoT-in-a-box dev kit [MIPS]  (Leído 2999 veces)
Desconectado JamesTaggart
« en: 25 de Noviembre de 2015, 15:49:31 »
https://www.kickstarter.com/projects/imgtec/creator-ci40-the-ultimate-iot-in-a-box-dev-kit
Placa de desarrollo basada en la arquitectura MIPS, podrá utilizar sistemas operativos OpenWRT, Linux Debian, Brillo, etc. Utilizará módulos de Mikroelectronika.
Maker-friendly interfaces (mikroBUS, Raspberry Pi, etc.)
The Creator Ci40 board features a number of peripheral I/Os, including a mikroBUS socket and a Raspberry Pi pin-compatible interface.
The two mikroBUS Clicker sockets can be used to instantly plug compatible devices with minimum set-up. MikroElektronika’s portfolio includes hundreds of mikroBUS compatible Click boards, providing the community with the ability to expand designs with additional functionality and minimum hardware configuration.
Alternatively, you can switch to the Raspberry Pi-compatible interface that enables you to port your existing Raspberry Pi projects over to Creator.
The complete hardware specifications
Creator Ci40 development board
CPU: 550 MHz dual-core, dual-threaded MIPS interAptiv, 32/32 kB L1 I- and D-cache per CPU, 512 kB L2 cache, IEEE 754 Floating Point Unit
RAM: 256 MB DDR3 SDRAM
Memory: 512 MB NAND flash, 1 x micro SD card
Communications: 802.11b/g/n/ac 2x2 Wi-Fi (Ensigma™ C4500 RPU), 802.15.4 6LoWPAN dedicated chip, Bluetooth 4.1 (Classic + Smart, respectively)
Security: Dedicated TPM chip
Ethernet: 1 x RJ45 Ethernet port
Audio: 1 x 3.5mm input/output jack, 1 x S/PDIF input/output connector
I/O: 32 x GPIO, 2 x mikroBUS i/f, 4 x PWM, 1 x SPI, 2 x UART, 2 x I2C, 5 x ADC, expansion headers, 14-pin EJTAG connector, 9 x indicator LEDs (7 x I/O, 1 x MCU),
USB: 1 x micro USB 2.0 OTG
Power: Micro USB (5V DC) or barrel adapter (9V DC)
Dimensions: 100 mm x 106 mm
Re:Creator Ci40: The ultimate IoT-in-a-box dev kit [MIPS]
« Respuesta #1 en: 25 de Noviembre de 2015, 18:01:01 »
El tema es el costo, no parece tener mucho como para que cueste bastante. A excepcion de la CPU+RAM+Flash para manejar que ? Ethernet y Wi-Fi ? No me convence desde el putno de vista electronico, si como para un informatico.
Las placas que traen como modulos me parecen totalmente absurdas ( sensor de movimiento?, temperatura ?, Rele ? ), miles preferirian un arduino para eso. un Rpy si es que queres lidiar con un Sistema operativo. Ademas los otros tienen salida de video si no me equivoco.
Al menos a mi no me convence como para apoyarlos economicamente.
PD: Vi que el de 6LoWPAN tiene PIC32 :P
Desconectado Geo
    • Mexchip
« Respuesta #2 en: 25 de Noviembre de 2015, 19:25:38 »
Por quienes lo promueven se nota que va más por el lado de promover la arquitectura MIPS.
La imaginación es el límite.
« Respuesta #3 en: 25 de Noviembre de 2015, 20:16:22 »
Al parecer esta primera versión tiene como objetivo crear una placa de desarrollo utilizando arquitectura MIPS que vaya a medio camino entre  las placas Cortex-Mx/PIC32Mx y RasPi&clones.
De tener éxito permitiría a MIPS no perder el tren de IoT y por otro lado complementar los productos PIC32Mx.
Utiliza interfaces compatibles con RasPi y mikroBus (el cual no tengo información si es de estándar abierto, aunque usa pines de 0.1").
Por otro lado promoverán la creación de repositorios libres por parte de la comunidad.
Los últimos años Arduino está desplazando a Microchip en el sector de "hobbie" y ARM tiene casi todo el mercado "maker" y profesional. Podría ser una de las últimas tentativas de mantenerse en el mercado para MIPS y Microchip.
« Respuesta #4 en: 25 de Noviembre de 2015, 20:42:27 »
No estoy de acuerdo con esto, microchip tiene mucho mercado, y ARM y MIPS no son los únicos núcleos que existen, hay muchos, cuenta los de intel, AMD, powerPC, ARM, MIPS, 8051, NVIDIA.
Cada uno tiene su mercado, y no por ello van a desaparecer ni se van a dejar de usar, ARM tiene mas mercado que otros, si es verdad, pero vete al sector automovilístico por ejemplo y veras que no se usa mucho ARM, por ponerte un ejemplo.
Y mucho menos en el tema microcontroladores que lo que cuenta son los periféricos.
Vamos yo diría casi al 100% seguro que microchip no va a desaparecer por los ARM
« Respuesta #5 en: 27 de Noviembre de 2015, 14:31:09 »
FYI:
"Un consorcio de empresas liderado por ARM Holdings también ha alcanzado un acuerdo para hacerse con los derechos de las 580 patentes de MIPS por 350 millones de dólares."
http://www.siliconweek.es/projects/imagination-technologies-proveedor-de-chips-graficos-para-apple-compra-mips-29230
