Autor Tema: PIC32MK0512MCF100, 120Mhz MIPS32, DSP-Enhanced Core  (Leído 3833 veces)
Desconectado JamesTaggart
« en: 16 de Julio de 2017, 19:47:11 »
PIC32MK0512MCF100
120Mhz MIPS32 microAptiv MCU Core
Floating Point Unit for single and double precision math
MicroMIPS Mode for 40% smaller code size
DSP-Enhanced Core:
Four 64-bit Accumulators
Single Cycle MAC supporting saturating and fractional math
Features
DSP-Enhanced Core:
512KB Dual Panel Flash with Live Update support
4KB EEPROM
High Performance Analog Front End
7x 12-bit 3.75MSPS ADC Cores up to 42 analog inputs
Four Op amps
Five analog comparators
Up to three 12-bit DACs
Motor Control PWM
 Eight PWM pairs
 Six additional Single-Ended PWM modules
 Dead Time for rising and falling edges
 Dead-Time Compensation
 8 ns PWM Resolution
 Clock Chopping for High-Frequency Operation
 PWM Support for:
 DC/DC, AC/DC, inverters, PFC, lighting
 BLDC, PMSM, ACIM, SRM motors
 Choice of six Fault and Current Limit Inputs
 Flexible Trigger Configuration for ADC Triggering
Output Compare / Input Captures / RTCC
 Up to 6 Quadrature Encoder Interface (QEI) Modules
 16 Output Compare
 16 Input Capture
 RTCC
Extensive Communication Interfaces
 Two FS USB 2.0 OTG controllers
 FourCAN2.0 Modules
 Up to six UART Modules (up to 25Mbps) with LIN and IrDA support
 Up to six SPI/I2S modules
 Peripheral Pin Select  (PPS) to enable remapable pin functions
Qualification and Class B Support
 AEC-Q100 REVG (Grade 1 -40ºC to +125ºC) (planned)
 Class B Safety Library, IEC 60730 (planned)
 Back-up internal oscillator
 Programmable High/Low-Voltage Detect module
 Clock monitor with Back-up Internal Oscillator
 Global register locking
Debugger Development Support
 In-circuit and in-application programming
 2-wire or 4-wire MIPS® Enhanced JTAG interface
 Unlimited software and 12 complex breakpoints
 IEEE 1149.2-compatible (JTAG) boundary scan
 Non-intrusive hardware-based instruction trace
