Autor Tema: Me podrian ayudar con estos warning????  (Leído 2700 veces)
Desconectado novato_todo_pic
« en: 30 de Diciembre de 2017, 23:38:43 »
HOla , no se que significan estos warnings con F9, si pueden desirme como quitarlos?
Warning[230] H:\PROYECTOS_NIPLE\VIVERO3_18F4550\VIVERO.ASM 68 : __CONFIG has been deprecated for PIC18 devices.  Use directive CONFIG.
Warning[230] H:\PROYECTOS_NIPLE\VIVERO3_18F4550\VIVERO.ASM 69 : __CONFIG has been deprecated for PIC18 devices.  Use directive CONFIG.
Warning[230] H:\PROYECTOS_NIPLE\VIVERO3_18F4550\VIVERO.ASM 70 : __CONFIG has been deprecated for PIC18 devices.  Use directive CONFIG.
Warning[230] H:\PROYECTOS_NIPLE\VIVERO3_18F4550\VIVERO.ASM 71 : __CONFIG has been deprecated for PIC18 devices.  Use directive CONFIG.
Warning[230] H:\PROYECTOS_NIPLE\VIVERO3_18F4550\VIVERO.ASM 72 : __CONFIG has been deprecated for PIC18 devices.  Use directive CONFIG.
Warning[230] H:\PROYECTOS_NIPLE\VIVERO3_18F4550\VIVERO.ASM 73 : __CONFIG has been deprecated for PIC18 devices.  Use directive CONFIG.
Warning[230] H:\PROYECTOS_NIPLE\VIVERO3_18F4550\VIVERO.ASM 74 : __CONFIG has been deprecated for PIC18 devices.  Use directive CONFIG.
Warning[230] H:\PROYECTOS_NIPLE\VIVERO3_18F4550\VIVERO.ASM 75 : __CONFIG has been deprecated for PIC18 devices.  Use directive CONFIG.
Warning[230] H:\PROYECTOS_NIPLE\VIVERO3_18F4550\VIVERO.ASM 76 : __CONFIG has been deprecated for PIC18 devices.  Use directive CONFIG.
Warning[230] H:\PROYECTOS_NIPLE\VIVERO3_18F4550\VIVERO.ASM 77 : __CONFIG has been deprecated for PIC18 devices.  Use directive CONFIG.
Warning[230] H:\PROYECTOS_NIPLE\VIVERO3_18F4550\VIVERO.ASM 78 : __CONFIG has been deprecated for PIC18 devices.  Use directive CONFIG.
Warning[230] H:\PROYECTOS_NIPLE\VIVERO3_18F4550\VIVERO.ASM 79 : __CONFIG has been deprecated for PIC18 devices.  Use directive CONFIG.
Warning[208] H:\PROYECTOS_NIPLE\VIVERO3_18F4550\VIVERO.ASM 13740 : Label truncated at 32 characters. (disp_i2c_mem24c02_01_escribir_mem)
Warning[208] H:\PROYECTOS_NIPLE\VIVERO3_18F4550\VIVERO.ASM 13811 : Label truncated at 32 characters. (disp_i2c_mem24c02_01_leer_memoria)
Warning[208] H:\PROYECTOS_NIPLE\VIVERO3_18F4550\VIVERO.ASM 13921 : Label truncated at 32 characters. (disp_i2c_mem24c02_01_txb_d0_d1_lp)
Warning[208] H:\PROYECTOS_NIPLE\VIVERO3_18F4550\VIVERO.ASM 13943 : Label truncated at 32 characters. (disp_i2c_mem24c02_01_rxb_d0_d1_lp)
Re:Me podrian ayudar con estos warning????
« Respuesta #1 en: 31 de Diciembre de 2017, 15:02:23 »
Hola amigo, no entiendo lo que quietes decir con F9.
En cuanto a los errores me imagino que los ves al editar el fichero list o errores después de la compilación.
No indicas si termina de forma correcta o no la compilación. Si quieres una ayuda más a fondo debes adjuntar el fichero npl para compilarlo y ver exactamente de que se tratan esos errores.
Alguno de ellos indican que los nombres de algunas cosas son muy largos.
« Respuesta #2 en: 31 de Diciembre de 2017, 15:39:30 »
Te está dando dos tipos de avisos.
1.- Deprecated: es algo obsoleto, que aún está soportado en la versión actual, pero que será eliminado en la próxima, por eso te recomiendan reemplazarlo ya, para evitar errores en cuanto lo eliminen. Ahí te dice que __CONFIG está obsoleto, que lo reemplaces por la directiva CONFIG. Mírate en el manual de ensamblador del micro, como configurar la directiva CONFIG.
2.- Etiqueta demasiado larga: no uses etiquetas de más de 32 caracteres, o te las trunca a esa longitud máxima. No te dará errores de compilación, si el truncado no hace que dos etiquetas queden con el mismo nombre. Mejor acostumbrarte a usar etiquetas que no pasen de 32 caracteres. Aunque al final, una etiqueta se convierte en una dirección de memoria, no debería de existir tal limitación, pero la hay en ese compilador.
« Respuesta #3 en: 31 de Diciembre de 2017, 20:38:29 »
Bueno , muchas gracias por la informacion, es que me aparecieron estos warning pero igualmente me genera el .hex , lo que sucede es que el hex termino funcionando mal y pense que solucionando los warning por ahi se mejoraba y andaria como debe,  pero por lo visto no me va a solucionar nada.
