Autor Tema: Pasar de MikroC a PIC C Compiler  (Leído 2924 veces)
Desconectado robo_z
« en: 05 de Enero de 2020, 21:57:00 »
Hola Amigos
Estoy Tratando de Pasar Un Codigo que Encontre en la WEB, Este Esta Hecho en Mikro C y Me Gustaria poder Pasarlo a CCS.
El Codigo en Cuestion es Este:
sbit Output_LED at GP5_bit;
unsigned short i, TIME_UP;
void interrupt(void){
  if(PIR1.TMR1IF) {
    i ++;
    if(i == 3) TIME_UP = 1;  // Time Up in 1.5 sec
    PIR1.TMR1IF = 0;
void main() {
  TRISIO = 0b00000011 ;
  ANSEL = 0x00;
  INTCON = 0b11000000 ; // Enable GIE and PEIE for Timer1 overflow interrpt
  PIE1 = 0b00000001 ;   // Enable TMR1IE
  // Configure Comparator module
  // CIN- pin is configured as analog,
  // CIN+ pin is configured as I/O,
  // COUT pin is configured as I/O,
  // Comparator output available internally,
  // CVREF is non-inverting input
  // CINV is set to 1
  CMCON0 = 0b00010100;
  VRCON  = 0b10100011;  // Vref is set to VDD/8
  Output_LED = 0;
  do{
     TMR1H = 0x00;
     TMR1L = 0x00;
     TIME_UP = 0;
     i = 0;
     T1CON = 0b00110000;   // Configure Timer 1
     if(CMCON0.COUT){      // First clap detected
       Delay_ms(100);
       T1CON.TMR1ON = 1;   // Start Timer1
       while(!CMCON0.COUT && !TIME_UP); // Wait until second clap is
       T1CON.TMR1ON = 0;                      // detected or Timer1 overflows
       if(CMCON0.COUT && !TIME_UP) Output_LED = ~Output_LED;
       Delay_ms(100);
  }  while(1);
Esto es lo que Tengo:
#include <12F675.h>
#device ADC=10
#FUSES PUT                      //Power Up Timer
#FUSES NOMCLR                   //Master Clear pin used for I/O
#FUSES PROTECT                  //Code protected from reads
#FUSES CPD                      //Data EEPROM Code Protected
#use delay(internal=4MHz)
#use fast_io(A)
#define ACT_RELE     PIN_A5 //Aqui Conectamos la Etapa del RELE
unsigned int Contador;
unsigned short TiempoTerminado;
#INT_TIMER1
void  TIMER1_isr(void)
   Contador++;
   if ( Contador == 3 )
    TiempoTerminado = 1;
void main()
   set_tris_a(0x02);
   setup_comparator(A1_VR | COMP_INVERT); //Configuramos el Comparador A1 vs Vref e Invertimos la Salida
   setup_vref(VREF_HIGH | 12); //Configuramos el Vref a 3.13v
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_8); //524 ms overflow
   enable_interrupts(GLOBAL);
   output_a(0x00);
   while(TRUE)
set_timer1(0);
Contador = 0;
TiempoTerminado = 0;
if ( C1OUT == 1 ) //Detectamos el Primer Aplauso
        delay_ms(100);
OJO He Cambiado El Valor de Vref que traia Originalmente para adecuarlo a mis Necesidades, Donde Me Quedo Atorado es en las Instrucciones :
- TMR1ON
- !CMCON0.COUT && !TIME_UP
- CMCON0.COUT && !TIME_UP
De Antemano Agradesco Su Ayuda :).
« Última modificación: 05 de Enero de 2020, 22:02:25 por robo_z »
Re:Pasar de MikroC a PIC C Compiler
« Respuesta #1 en: 05 de Enero de 2020, 22:07:34 »
Para cuando T1ON es 0, significa que esta parado el Timer, lo logras con:
  1. setup_timer_1 ( T1_DISABLED );
Si queres activarlo, usas el setup timer del comienzo.
  1. !CMCON0.COUT
Este va a estar complicado, seguramente sea mejor definir el bit con #BIT, aunque lo mismo podes hacer para lo del timer...
Y respecto al !TIME_UP no tiene nada de CCS.
Desconectado robo_z
« Respuesta #2 en: 05 de Enero de 2020, 22:27:50 »
Primeramente muchas gracias por tomarte un tiempo para ayudarme.
Es Cierto TIME_UP, es una Variable pero para el caso de "!CMCON0.COUT" me parece que puede ser asi "!C1OUT" y su equivalente seria "C1OUT != 1", Alguien que me Corrija.
Y para el Caso de "PIR1.TMR1IF = 0" (Limpiar la Bandera del Timer 1) seria "clear_interrupt(int_timer1)"; de igual manera si estoy mal alguien que me corrija.
Nuevamente Muchas Gracias por la Ayuda.
« Última modificación: 05 de Enero de 2020, 22:29:59 por robo_z »
« Respuesta #3 en: 05 de Enero de 2020, 23:21:21 »
Es correcto, solo necesitas definir ese bit... ya que CCS busca que no toques los registros, pero te da la posibilidad de hacerlo con #BIT y #BYTE
