Autor Tema: dht22 y bmp180  (Leído 1348 veces)
Desconectado javiergggg
dht22 y bmp180
« en: 25 de Agosto de 2021, 15:38:09 »
estoy tratando de tomar el dato de presión del bmp180, y del dht22; con el dht22 no tengo problemas...leo perfecto temp y humedad..., pero se me cuelga con  bmp085Calibration();
alguien tuvo el mismo problema...????
#include <16F876A.h>
#fuses HS,NOWDT,PUT
#use delay(clock=20Mhz)
#use i2c(master, sda=PIN_C4, scl=PIN_C3, FAST=100000, FORCE_SW)
#include <i2c_Flex_LCD.c>
#include "BMP180.c"//*-------------------------------------------------------------------------------------------------------------------------------------
#use fast_io(B)
#use fast_io(C)
#BIT Data_Pin = 0x06.7                       // Pin mapped to PORTB.7
#BIT Data_Pin_Direction = 0x86.7             // Pin direction mapped to TRISB.7
float P_mBar,T_Cent;
char message1[] = "Temp = 00.0 C";
char message2[] = "RH   = 00.0 %";
short Time_out ;
unsigned int8 T_byte1, T_byte2, RH_byte1, RH_byte2, CheckSum ;
unsigned int16 Temp, RH;
void start_signal(){
  Data_Pin_Direction = 0;              // Configure connection pin as output
  Data_Pin = 0;                        // Connection pin output low
  delay_ms(25);
  Data_Pin = 1;                        // Connection pin output high
  delay_us(30);
  Data_Pin_Direction = 1;              // Configure connection pin as input
short check_response(){
  delay_us(40);
  if(!Data_Pin){                     // Read and test if connection pin is low
    delay_us(80);
    if(Data_Pin){                    // Read and test if connection pin is high
      delay_us(50);
      return 1;}
unsigned int8 Read_Data(){
  unsigned int8 i, k, _data = 0;     // k is used to count 1 bit reading duration
  if(Time_out)
    break;
  for(i = 0; i < 8; i++){     k = 0;     while(!Data_Pin){ // Wait until pin goes high       k++;       if (k > 100) {Time_out = 1; break;}
      delay_us(1);}
    delay_us(30);
    if(!Data_Pin)
      bit_clear(_data, (7 - i));               // Clear bit (7 - i)
    else{
      bit_set(_data, (7 - i));                 // Set bit (7 - i)
      while(Data_Pin){                         // Wait until pin goes low
      k++;
      delay_us(1);}
  return _data;
void main()
            lcd_init(0x4E,16,4);
            delay_ms(50);
            lcd_gotoxy(5,1);
            lcd_putc("-PTU-AR-");
            //*bmp085Calibration();
while(1)
            delay_ms(1000);
            Time_out = 0;
            Start_signal();
                        if(check_response()){                    // If there is response from sensor
                                             RH_byte1 = Read_Data();                 // read RH byte1
                                             RH_byte2 = Read_Data();                 // read RH byte2
                                             T_byte1 = Read_Data();                  // read T byte1
                                             T_byte2 = Read_Data();                  // read T byte2
                                             Checksum = Read_Data();                 // read checksum
                       if(Time_out){                           // If reading takes long time
                                    lcd_putc('f');                       // LCD clear
                                    lcd_gotoxy(5, 1);                     // Go to column 5 row 1
                                    lcd_putc("Time out!");
                               else{
                                   if(CheckSum == ((RH_Byte1 + RH_Byte2 + T_Byte1 + T_Byte2) & 0xFF))
        RH = RH_byte1;
        RH = (RH << 8) | RH_byte2;
        Temp = T_byte1;
        Temp = (Temp << 8) | T_byte2;
        if (Temp > 0x8000){
        message1[6] = '-';
        Temp = Temp & 0x7FFF;
        else
        message1[6] = ' ';
        message1[7]  = (Temp / 100) % 10  + 48;
        message1[8]  = (Temp / 10) % 10  + 48;
        message1[10] = Temp % 10  + 48;
        message2[7]  = (RH / 100) % 10 + 48;
        message2[8]  = (RH / 10) % 10 + 48;
        message2[10] = RH % 10 + 48;
        message1[11] = 223;                   // Degree symbol
        //*lcd_putc('f');                       // LCD clear
        lcd_gotoxy(1,2);                     // Go to column 1 row 1
        printf(lcd_putc, message1);           // Display message1
        lcd_gotoxy(1,3);                     // Go to column 1 row 2
        printf(lcd_putc, message2);           // Display message2
        else {
          lcd_gotoxy(1, 1);                   // Go to column 1 row 1
          lcd_putc("Checksum Error!");
    else {
      lcd_gotoxy(3, 1);           // Go to column 3 row 1
      lcd_putc("No response");
      lcd_gotoxy(1, 2);           // Go to column 1 row 2
      lcd_putc("from the sensor");
    delay_ms(100);
   //*P_mBar = BMP085Pressure(false);//*----------------------------------------------------------------------------------------------------------------------------
   //*T_Cent = BMP085Temperature();
    lcd_gotoxy(1,4);
    printf(lcd_putc "Pres = %0.1f hPa",P_mBar);//*-
