Autor Tema: Ayuda con el Empleo del comando Printf para el envio via rs232 DHT11 CCS CODE  (Leído 1568 veces)
Desconectado GAMCH333
Buenos días!!
Una vez mas solicitando su ayuda he logrado interconectar el sensor DHT11 a un PIC16F877, teniendo como resultado el poder observar las variables humedad y temperatura en una pantalla de lcd 16x2, como se muestre en el siguiente programa.
// Interfacing PIC16F877A with DHT11 sensor
// http://ccspicc.blogspot.com/
// electronnote@gmail.com
//LCD module connections PUERTO B
#define LCD_RS_PIN PIN_B0
#define LCD_RW_PIN PIN_B1
#define LCD_ENABLE_PIN PIN_B2
#define LCD_DATA4 PIN_B3
#define LCD_DATA5 PIN_B4
#define LCD_DATA6 PIN_B5
#define LCD_DATA7 PIN_B6
//End LCD module connections
#include <16F876.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP
#use delay(clock = 8000000)
#use rs232 (BAUD=9600, XMIT=PIN_C6, RCV=PIN_C7)      // Tx a 9600 BAUDS VIA RS-232 STANDAR
#include <lcd_B.c>
#use fast_io(A)
// Connection pin between PIC16F877A and DHT11 (RHT01) sensor ENTRADA RA0
#BIT Data_Pin = 0x05.0                       // Pin mapped to PORTA.0
#BIT Data_Pin_Direction = 0x85.0             // Pin direction mapped to TRISA.0
char message1[] = "Temp = 00.0 C";
char message2[] = "RH   = 00.0 %";
short Time_out;
unsigned int8 T_byte1, T_byte2, RH_byte1, RH_byte2, CheckSum ;
void start_signal()
  Data_Pin_Direction = 0;              // Configure connection pin as output
  Data_Pin = 0;                        // Connection pin output low
  delay_ms(25);
  Data_Pin = 1;                        // Connection pin output high
  delay_us(30);
  Data_Pin_Direction = 1;              // Configure connection pin as input
short check_response()
  delay_us(40);
  if(!Data_Pin)
  {                     // Read and test if connection pin is low
    delay_us(80);
    if(Data_Pin)
    {                    // Read and test if connection pin is high
      delay_us(50);
      return 1;
unsigned int8 Read_Data()
  unsigned int8 i, k, _data = 0;     // k is used to count 1 bit reading duration
  if(Time_out)
    break;
  for(i = 0; i < 8; i++)
    k = 0;
    while(!Data_Pin)
    {                          // Wait until pin goes high
      k++;
      if (k > 100)
       Time_out = 1; break;
      delay_us(1);
    delay_us(30);
    if(!Data_Pin)
      bit_clear(_data, (7 - i));               // Clear bit (7 - i)
    else
      bit_set(_data, (7 - i));                 // Set bit (7 - i)
      while(Data_Pin)
      {                         // Wait until pin goes low
      k++;
      if (k > 100) {Time_out = 1; break;}
      delay_us(1);
  return _data;
void main()
  lcd_init();                                 // Initialize LCD module
  lcd_putc('\f');                             // LCD clear
  while(TRUE)
    delay_ms(1000);
    Time_out = 0;
    Start_signal();
    if(check_response())
    {                    // If there is response from sensor
      RH_byte1 = Read_Data();                 // read RH byte1
      RH_byte2 = Read_Data();                 // read RH byte2
      T_byte1 = Read_Data();                  // read T byte1
      T_byte2 = Read_Data();                  // read T byte2
      Checksum = Read_Data();                 // read checksum
      if(Time_out)
      {                           // If reading takes long time
        lcd_gotoxy(5, 1);                     // Go to column 5 row 1
        lcd_putc("Time out!");
      else
       if(CheckSum == ((RH_Byte1 + RH_Byte2 + T_Byte1 + T_Byte2) & 0xFF))
        message1[7]  = T_Byte1/10  + 48;
        message1[8]  = T_Byte1%10  + 48;
        message1[10] = T_Byte2/10  + 48;
        message2[7]  = RH_Byte1/10 + 48;
        message2[8]  = RH_Byte1%10 + 48;
        message2[10] = RH_Byte2/10 + 48;
        message1[11] = 223;
                                               // Degree symbol
        lcd_gotoxy(1, 1);                     // Go to column 1 row 1
        printf(lcd_putc, message1);           // Display message1
        lcd_gotoxy(1, 2);                     // Go to column 1 row 2
        printf(lcd_putc, message2);           // Display message2
                                              // Envio RS232
        printf("%2d.%1d",message1[8],message1[10]);
        printf("%2d.%1d",message2[8],message2[10]);
        printf("\n\r");           // Display message2
pero el resultado en la hyperterminar me son incorrectos dando como resultados estos.
50.9849.48
50.4849.48
50.9849.48
50.4849.48
50.9849.48
50.4849.48
Cuando lo que pretendo es poder obtener el valor de temperatura, y humedad separos por una coma como muestro a continuación:
22.0,30.0
22.0,30.0
22.0.30.0
Y entiendo que es por que utilizo mal el comando fprintf  .
Por favor ..Cualquier ayuda que me puedan brindar sobre la manera correcta de utilizar dicho comando se los agradeceré.
Sin mas por el momento reciban un saludo.
Re:Ayuda con el Empleo del comando Printf para el envio via rs232 DHT11 CCS CODE
« Respuesta #1 en: 06 de Marzo de 2024, 22:52:12 »
Si no escribís la coma, no va a aparecer...
        printf("%2d.%1d,",message1[8],message1[10]);
« Respuesta #2 en: 07 de Marzo de 2024, 10:34:22 »
Por otro lado, lo que tenés en message1[]  es texto, y el switch %2d  es para un dato numérico.
Tal como está message[], deberías haber escrito:   printf("%c%c.%c,",message1[7],message1[8],message1[10]);
