Autor Tema: PROBLEMAS DE COMPILACION  (Leído 2482 veces)
Desconectado tekag
« en: 29 de Marzo de 2005, 10:33:00 »
Hola gente!:
Tengo un problema con los defines en 2 ejercicios que vienen con el compilador PCW compiler version 3.34.
Resulta que vienen dos ejercicios con LCD que no puedo compilar porque me da un error en la libreria LCD.C
Si alguien tiene el mismo compilador que yo se daran cuenta a que me refiero.Los archivos son Ex_lcdkb y EX_lcdth.
Cuando intento compilarlos me da un error de "undefined identifier set_tris_d en la lireria LCD.C.
Como no puedo adjuntar los 3 archivos te los copio aqui:Por ejemplo detallo el
archivo EX_lcdth.c:
////                         EX_LCDTH.C                              ////
////  This example demonstartes the use of the DS1621 chip.  The     ////
////  example reads the temperature and then sends it over RS232 and ////
////  to a LCD.                                                      ////
////  Configure the CCS prototype card as follows:                   ////
////     Connect pin 32 to pin 40.                                   ////
////     Make the following connections:                             ////
////          DS1621 pin     Protoboard                              ////
////              1             1   C0 (also use pull up resistor)   ////
////              2             2   C1 (also use pull up resistor)   ////
////              3            No connection                         ////
////              4            27   Gnd                              ////
////              5            27   Gnd                              ////
////              6            27   Gnd                              ////
////              7            27   Gnd                              ////
////              8            28   +5V                              ////
////     See additional connections below.                           ////
////  This example will work with the PCB, PCM and PCH compilers.    ////
////  The following conditional compilation lines are used to        ////
////  include a valid device for each compiler.  Change the device,  ////
////  clock and RS232 pins for your hardware if needed.              ////
////        (C) Copyright 1996,2003 Custom Computer Services         ////
//// This source code may only be used by licensed users of the CCS  ////
//// C compiler.  This source code may only be distributed to other  ////
//// licensed users of the CCS C compiler.  No other use,            ////
//// reproduction or distribution is permitted without written       ////
//// permission.  Derivative programs created using this software    ////
//// in object code form are not restricted in any way.              ////
#if defined(__PCB__)
#include <16c56.h>
#fuses HS,NOWDT,NOPROTECT
#use delay(clock=20000000)
#elif defined(__PCM__)
#include <16F877.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP
#elif defined(__PCH__)
#include <18F452.h>
#fuses HS,NOPROTECT,NOLVP
#endif
#include <lcd.c>
#include <ds1621.c>
#define RESET_BUTTON    PIN_d0
int current_temp, max_temp, min_temp;
void reset_temp()  {
   current_temp = read_temp();
   min_temp=current_temp;
   max_temp=current_temp;
void main() {
   init_temp();
   lcd_init();
   delay_ms(6);
   reset_temp();
   while(TRUE)
      if(input(RESET_BUTTON)==0)
         reset_temp();
      else if(current_temp>max_temp)
      else if(current_temp<min_temp)
      printf(lcd_putc,"fCurrent Temp: %U F
Min: %U Max: %U",current_temp,min_temp,max_temp);
      delay_ms(500);
////                             LCDD.C                                ////
////                 Driver for common LCD modules                     ////
////  lcd_init()   Must be called before any other function.           ////
////  lcd_putc(c)  Will display c on the next position of the LCD.     ////
////                     The following have special meaning:           ////
////                      f  Clear display                            ////
  Go to start of second line               ////
////                        Move back one position                   ////
////  lcd_gotoxy(x,y) Set write position on LCD (upper left is 1,1)    ////
////  lcd_getc(x,y)   Returns character at position x,y on LCD         ////
//// This source code may only be used by licensed users of the CCS C  ////
//// compiler.  This source code may only be distributed to other      ////
//// licensed users of the CCS C compiler.  No other use, reproduction ////
//// or distribution is permitted without written permission.          ////
//// Derivative programs created using this software in object code    ////
//// form are not restricted in any way.                               ////
// As defined in the following structure the pin connection is as follows:
//     D0  enable
//     D1  rs
//     D2  rw
//     D4  D4
//     D5  D5
//     D6  D6
//     D7  D7
//   LCD pins D0-D3 are not used and PIC D3 is not used.
// Un-comment the following define to use port B
// #define use_portb_lcd TRUE
struct lcd_pin_map {                 // This structure is overlayed
           boolean enable;           // on to an I/O port to gain
           boolean rs;               // access to the LCD pins.
           boolean rw;               // The bits are allocated from
           boolean unused;           // low order up.  ENABLE will
           int     data : 4;         // be pin B0.
        } lcd;
#if defined(__PCH__)
#if defined use_portb_lcd
   #byte lcd = 0xF81                   // This puts the entire structure
#else
   #byte lcd = 0xF83                   // This puts the entire structure
#endif
#else
   #byte lcd = 6                  // on to port B (at address 6)
#else
   #byte lcd = 8                 // on to port D (at address 8)
#endif
#endif
   #define set_tris_lcd(x) set_tris_b(x)
#else
   #define set_tris_lcd(x) set_tris_d(x)
#endif
#define lcd_type 2           // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40    // LCD RAM address for the second line
byte CONST LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
                             // These bytes need to be sent to the LCD
                             // to start it up.
                             // The following are used for setting
                             // the I/O port direction register.
STRUCT lcd_pin_map const LCD_WRITE = {0,0,0,0,0}; // For write mode all pins are out
STRUCT lcd_pin_map const LCD_READ = {0,0,0,0,15}; // For read mode data pins are in
byte lcd_read_byte() {
      byte low,high;
      set_tris_lcd(LCD_READ);
      lcd.rw = 1;
      delay_cycles(1);
      lcd.enable = 1;
      delay_cycles(1);
      high = lcd.data;
      lcd.enable = 0;
      delay_cycles(1);
      lcd.enable = 1;
      delay_us(1);
      low = lcd.data;
      lcd.enable = 0;
      set_tris_lcd(LCD_WRITE);
      return( (high<<4) | low);
void lcd_send_nibble( byte n ) {
      lcd.data = n;
      delay_cycles(1);
      lcd.enable = 1;
      delay_us(2);
      lcd.enable = 0;
void lcd_send_byte( byte address, byte n ) {
      lcd.rs = 0;
      while ( bit_test(lcd_read_byte(),7) ) ;
      lcd.rs = address;
      delay_cycles(1);
      lcd.rw = 0;
      delay_cycles(1);
      lcd.enable = 0;
      lcd_send_nibble(n >> 4);
      lcd_send_nibble(n & 0xf);
void lcd_init() {
    byte i;
    lcd.rs = 0;
    lcd.rw = 0;
    lcd.enable = 0;
    delay_ms(15);
    for(i=1;i<=3;++i) {
       lcd_send_nibble(3);
       delay_ms(5);
    lcd_send_nibble(2);
    for(i=0;i<=3;++i)
       lcd_send_byte(0,LCD_INIT_STRING);
void lcd_gotoxy( byte x, byte y) {
   byte address;
   if(y!=1)
     address=lcd_line_two;
   else
     address=0;
   address+=x-1;
   lcd_send_byte(0,0x80|address);
void lcd_putc( char c) {
   switch (c) {
     case "f"   : lcd_send_byte(0,1);
                   delay_ms(2);
                                           break;
     case "
"   : lcd_gotoxy(1,2);        break;
     case ""   : lcd_send_byte(0,0x10);  break;
     default     : lcd_send_byte(1,c);     break;
char lcd_getc( byte x, byte y) {
   char value;
    lcd_gotoxy(x,y);
    while ( bit_test(lcd_read_byte(),7) ); // wait until busy flag is low
    lcd.rs=1;
    value = lcd_read_byte();
    lcd.rs=0;
    return(value);
Cuando intento compilar este archivo me da error de "undefined identifier set_tris_d dentro de la libreria LCD.C
ME pueden dar una mano con esto??
Les mando un abrazo
Desconectado pocher
RE: PROBLEMAS DE COMPILACION
« Respuesta #1 en: 30 de Marzo de 2005, 00:20:00 »
Que raro que te salga ese error, creo que todo está bien.
Esto no creo que sea un error, seguramente lo tendrás bien:
void lcd_init() {
byte i;
lcd.rs = 0;
lcd.rw = 0;
lcd.enable = 0;
delay_ms(15);
for(i=1;i<=3;++i) {
lcd_send_nibble(3);
delay_ms(5);
lcd_send_nibble(2);
for(i=0;i<=3;++i)
Debiera de decir: lcd_send_byte(0,LCD_INIT_STRING);
Los corchetes no les dá la gana de sacarlos a mierda@
Desconectado tornar
« Respuesta #2 en: 30 de Marzo de 2005, 03:40:00 »
Este error me suena a que deberias poner algun #define diciendo la puerta a la que tienes conectado el LCD.
