Autor Tema: Clave incorrecta  (Leído 3008 veces)
Desconectado litris
Clave incorrecta
« en: 18 de Enero de 2004, 15:51:00 »
Haber si por aqui consigo el problema
¿Que puedo añadir para que al 3 fallo me suente el BUZZ durante 20 segundos y bloquee la entrada durante 30 segundos?
El codigo mas claro aqui http://jap.hu/electronic/cl2c.asm
;    Filename:       cl2.asm                                           *
;    Date:                                                            *
;    File Version:  Codelock rewritten                                *
;    Author:        el@jap.hu                                         *
;                   http://jap.hu/electronic/                         *
;NOTES
; the rewritten codelock has the following changes:
; - no multiplexer is needed (the old version used a generic devboard)
; - no row diodes needed (rows are never driven HIGH)
; - low power consumption due to keyboard wake-up
; - stores the code in the internal EEPROM
; - user defined codelength and pulse output
; - user adjustable running frequency
; - improved code changing function with a "change" indicator LED
; PIC ports used:
; PA0-3 outputs: row select pulldown outputs (tristate or driven LOW)
; PB1 output: code change indicator LED
; PB2 output: output pulse to control a relay
; PB3 output: piezo beeper output
; PB4-PB7 inputs: column inputs with internal pullup
;HISTORY
; 020-20010929 rewrite started
; 021-20011022 udelay calibrated to 100 usec (4, 10 MHz)
; 022-20011022 scan, input and compare functions work
; 023-20011022 code change function works
; 023c-20030816 Alan Carvalho de Assis add support to 8 passwords
   list   p=16f84a
   __CONFIG   _CP_OFF & _WDT_OFF & _PWRTE_ON & _HS_OSC
#include <p16F84a.inc>
mhz      EQU D"4" ; processor frequency in MHz
pulsewidth   EQU D"100"; delay in 20ms steps (150=3 sec)
clen      EQU  6    ; length of code
; EEPROM contents
      ORG 0x2100
              ; default codes (8 * clen chars are used)
              ; which is stored in EEPROM
      de    "074185"   ; password 1
      de   "741852"   ; password 2
      de   "418529"   ; password 3
      de   "185296"   ; password 4
      de   "852963"   ; password 5
      de   "529630"   ; password 6
      de    "296307"   ; password 7
      de   "963074"   ; password 8
      de   "630741"   ; password 9   ;;out of memory
      de    "307418"   ; password 10  ;;out of memory
; RAM registers
ram_start   EQU 0x0c
dcnt0      EQU ram_start+1 ; delay counter 0
dcnt1      EQU ram_start+2 ; delay counter 1
dcnt2      EQU ram_start+3 ; delay counter 2
beepcnt      EQU ram_start+4 ; beep cycle counter
keycode      EQU ram_start+5
rowcnt      EQU ram_start+6
colcnt      EQU ram_start+7
colstatus   EQU ram_start+8
cod      EQU ram_start+9 ; actual code
cod_end      EQU cod+(8*clen); eight password
readlen      EQU cod_end
readbuf      EQU cod_end+1
readbuf_end   EQU readbuf+clen
tmptr      EQU readbuf_end  ; pointer for comparing and copying readbuf
tmbyte      EQU readbuf_end+1; temp storage for comparing and copying
cntpass      EQU readbuf_end+2; counter password
currptr      EQU readbuf_end+3; pointer to current code
vectors      ORG 0
        goto main
      nop
      nop
      nop
      retfie
keytable   ;determine pressed key"s real code from scancode
      movf keycode, W
      addwf PCL, F
      dt 0x60
      dt "123a"
      dt "456b"
      dt "789c"
      dt "*0#d"
eep_read   ; read EEPROM contents to RAM from cod to cod_end-1
      movlw cod
      movwf FSR
      clrf EEADR
eep_0      ;bcf INTCON, GIE
      bsf STATUS, RP0
      bsf EECON1, RD
      bcf STATUS, RP0
      ;bsf INTCON, GIE
      movf EEDATA, W
      movwf INDF
      incf FSR, F
      incf EEADR, F
      movlw cod_end
      subwf FSR, W
      bnz eep_0
      return
eep_write   ; save RAM contents to EEPROM from cod to cod_end-1
      movlw cod
      movwf FSR
      clrf EEADR
eep_1      ;
      movf INDF, W
      movwf EEDATA
      ;bcf INTCON, GIE
      bsf STATUS, RP0
      bcf EECON1, EEIF
      bsf EECON1, WREN
      movlw 0x55
      movwf EECON2
      movlw 0xaa
      movwf EECON2
      bsf EECON1, WR
eep_2      ; wait for write completition
      bcf STATUS, RP0
      ;bsf INTCON, GIE
      nop
      nop
      ;bcf INTCON, GIE
      bsf STATUS, RP0
      btfss EECON1, EEIF
      goto eep_2
      bcf STATUS, RP0
      ;bsf INTCON, GIE
      incf FSR, F
      incf EEADR, F
      movlw cod_end
      subwf FSR, W
      bnz eep_1
      return
udelay      ; delay W * 100 usec
      movwf dcnt0
udelay0      ;
      movlw 8 * mhz
      movwf dcnt1
udelay1
      decfsz dcnt1, F
      goto udelay1
      decfsz dcnt0, F
      goto udelay0
      return
beep      ;
      movwf beepcnt
beep0      ;
      bsf PORTB, 3 ; beepctl bit
      movlw 3
      call udelay
      bcf PORTB, 3 ; beepctl bit
      movlw 3
      call udelay
      decfsz beepcnt, F
      goto beep0
      return
keyscan      ; scan the keyboard
      clrf keycode
      movlw 4
      movwf rowcnt
      movlw 0xfe
      tris PORTA ; select row 0
rowscan
      movlw 0xa0
      call udelay
      swapf PORTB, W
      movwf colstatus
      movlw 4
      movwf colcnt
colscan
      incf keycode, F
      rrf colstatus, F
      btfss STATUS, C
      goto keytable ; a key was found
      decfsz colcnt, F
      goto colscan
      bsf STATUS, C
      bsf STATUS, RP0
      rlf TRISA, F ; select next row
      bcf STATUS, RP0
      decfsz rowcnt, F
      goto rowscan
      retlw 0 ; no key was found
main      ; program starts here
      clrf PORTA
      clrw
      tris PORTA ; porta all output
      clrf PORTB
      movlw 0xf0 ; pb4-7 inputs
      tris PORTB
      bsf STATUS, RP0 ; bank 1
      bcf OPTION_REG, NOT_RBPU ;internal pullups on port B enabled
      bcf STATUS, RP0 ;bank 0
warm
      movlw 0xf0
      call beep
      call eep_read ; read code from eeprom to ram at cod
loop      clrf PORTB ; clear output
      call read ; read code from keyboard into readbuf
      movlw cod
      call compbuf ; compare code in readbuf with code at cod
      bnz loop ; the code is different
      ; the code matches, check which enter (#*) was pressed
      movlw "*"
      subwf keycode, W ; * changes code
      bz codechange
pulseout   ; # operates output
      movlw 0x04 ; RB2 is output
      movwf PORTB
      movlw pulsewidth
      movwf dcnt2
out0      movlw d"200"
      call udelay
      decfsz dcnt2, F
      goto out0
      goto loop
codechange   movlw 2        ; * changes code
      movwf PORTB    ; indicate changing the code
      call read      ; read new code into readbuf
      ;;movlw cod
      call copybuf ; copy new code into cod
      call read ; read new code twice
      movlw cod ; and check if the new code is confirmed
      call compbuf ; wrong code entry, restart with the original code
      bnz warm
      ; new code is comfirmed twice, store into eeprom
      call eep_write
      goto loop
read      clrf readlen
readloop   ; wait until no key is pressed
      clrw
      tris PORTA ; porta all LOW
      movf PORTB, W
      andlw 0xf0 ; keymask
      xorlw 0xf0
      btfss STATUS, Z
      goto readloop
      movlw  0xf0  ; wait 24 ms
      call udelay  ; (debounce)
      ; no key pressed, go to sleep
      movf PORTB, W
      movlw 1<<RBIE ; enable RB port change wake-up
      movwf INTCON
      sleep
key_pressed
      call keyscan
      andlw 0xff
      movwf keycode
      bz readloop
      ; check if the buffer is full
      movlw clen
      subwf readlen, W
      bnz read_notfull
      ; buffer is full, can return if an enter key (*#) is pressed
      ; check for ENTER
      call read_chkenter
      bnz read_notenter
      ; enter is pressed, return
      movlw 0x40
      call beep
      movf keycode, W
      return
read_notenter
      ; buffer is full, but more characters entered
      ; shift the buffer
      movlw readbuf+1
      movwf FSR
read_shift   movf INDF, W
      decf FSR, F
      movwf INDF
      incf FSR, F
      incf FSR, F
      movlw readbuf_end
      subwf FSR, W
      bnz read_shift
      decf readlen, F
read_notfull   call read_chkenter ; if the buffer is not full and an
      bz read ; enter key (*#) is pressed, clear buffer
      movlw 0x40
      call beep
      movlw readbuf
      addwf readlen, W
      movwf FSR
      movf keycode, W
      movwf INDF
      incf readlen, F
      goto readloop
read_chkenter   ; check if a * or # is pressed which indicates
      ; the end of entry
      movlw "#"
      subwf keycode, W
      btfsc STATUS, Z
      return ; Z=1, enter
      movlw "*"
      subwf keycode, W
      return
compbuf      ; compare read buffer to a code in RAM at W
      movwf tmptr       ; compare pointer
      clrf readlen      ; compare index starts from 0
      movlw 8      ; counter password decrement from 8
      movwf cntpass
      goto comp0
comp_next_pass
      movlw clen   ; add clen to tmptr to get next password
      addwf tmptr
      clrf  readlen   ; compare index starts from 0 again
      decfsz  cntpass   ;decrement password counter, if 0 return
      goto comp0
      movlw 255   ;wait
      call udelay
      movlw 0xF0   ;listen password incorrect
      call beep
      bcf STATUS, Z   ; Z=1: the code is different
      return
comp0      movlw readbuf
      addwf readlen, W
      movwf FSR
      movf INDF, W
      movwf tmbyte ; the read byte which is compared
      movf tmptr, W
      addwf readlen, W
      movwf FSR
      movf INDF, W ; the byte readbuf is compared to
      subwf tmbyte, W
      btfss STATUS, Z
      goto comp_next_pass   ;the current is diferente, test next password
      incf readlen, F
      movlw clen
      subwf readlen, W
      bnz comp0 ; compare next character
      ; Z=0: the code is the same
      return
copybuf      ; copy readbuf to RAM at W
      ;;movwf tmptr    ; copy pointer
      clrf readlen   ; copy index starts from 0
copy0      movlw readbuf
      addwf readlen, W
      movwf FSR
      movf INDF, W
      movwf tmbyte ; the read byte which is copied
      movf tmptr, W
      addwf readlen, W
      movwf FSR
      movf tmbyte, W ; the byte from readbuf
      movwf INDF
      incf readlen, F
      movlw clen
      subwf readlen, W
      bnz copy0 ; copy next character
      return
      end
