Autor Tema: PIC-Tengu  (Leído 218017 veces)
Desconectado moorat
Re: PIC-Tengu
« Respuesta #255 en: 12 de Diciembre de 2009, 19:09:59 »
What do I do now   :)
Desconectado jfmateos2
Re: PIC-Tengu
« Respuesta #256 en: 13 de Diciembre de 2009, 05:39:11 »
Let´s summarize:
  • Using your modified v0 HEX file for 2550 your PIC-Tengu seems to work, but slower than normal.
  • Using my modified v1 HEX file for 2550 (it is just the 2455 version changing the line #include <18F2550.h>) nothing happens in your PIC-Tengu, no led turns on.
I think your Xtal could be broken, or perhaps the Xtal capacitors, although this does not explain why v1 HEX file does not work in your PIC-Tengu.
I would check the PIC traces on the PCB, or even try a different PIC18F2550.
I hope yor will solve it soon.
Desconectado moorat
Re: PIC-Tengu
« Respuesta #257 en: 26 de Marzo de 2010, 03:37:13 »
hi again :) I made the circuit again. I have a problem like this once in the video. I won,der what's wrong?
Re: PIC-Tengu
« Respuesta #258 en: 26 de Marzo de 2010, 14:07:09 »
Dear Moorat, it could be a problem with the push button... this button is for changing the face animation and reseting the system...
In your video the face animation changes alone and suddendly appears the text animation...
This text animation should only appear the first time you power pic-tengu, so it seems that your pic-tengu is resetting itself...
By the way... Does the right eye led ever light or is always off?
Desconectado moorat
Re: PIC-Tengu
« Respuesta #259 en: 26 de Marzo de 2010, 15:24:29 »
I'm pressing the button and change text and right eye always off.
Can it possibly do to integrate circuit. I ordered pic18f2455 today.
Try it again at one and share with you my results.
Thank you for your help sir
Re: PIC-Tengu
« Respuesta #260 en: 26 de Marzo de 2010, 15:27:22 »
Ok moorat, don´t forget to tell us whether it works using the PIC18f2455
Best regards
Desconectado darck_khronos
Re: PIC-Tengu
« Respuesta #261 en: 26 de Mayo de 2011, 00:35:19 »
conecte el esquematico del microfono a mi pic al canal adc pero este no me muestrea nada solo un voltaje de 2.54 a 2.58 y cuando aplaudo este no pasa ni sube de ese rango alguna idea??
Re: PIC-Tengu
« Respuesta #262 en: 26 de Mayo de 2011, 01:18:23 »
¿Lo estás midiendo con un osciloscopio o con un multímetro?
Si es un osciloscopio, ve midiendo "aguas arriba" del amplificador a ver si está funcionando bien el micrófono.
Desconectado mulinee..46
Re: PIC-Tengu
« Respuesta #263 en: 20 de Julio de 2011, 17:29:04 »
Buenas noches..
jfmateos2, a mi me surge este problema..
cuando yo conecto el PIC-Tengu al ordenador, este lo detecta, pero el programa pictengu.exe no (bueno le doy al puerto que esta conectado, lo acepta pero se queda "pillado") pero al darle a la cruz, sale perfectamente..
que puedo hacer?
Re: PIC-Tengu
« Respuesta #264 en: 21 de Julio de 2011, 11:28:15 »
Hola mulinee,
Ahora mismo no tengo Windows y no puedo verificar cómo funcionaba el programa.
Según veo en el código fuente, si no se detectase el Pic-Tengu debería aparecer un mensaje indicándotelo.
Este mensaje no aparece, luego te lo ha detectado, entonces el programa solicita al PIC-Tengu que le mande el contenido actual de su EEPROM.
Yo creo que el problema debes tenerlo aquí porque es la primera vez que el programa manda datos al Tengu y muy probablemente estás recibiendo correctamente datos desde el Tengu pero no eres capaz de mandárselos desde el programa... esto me ha pasado a mí en otros proyectos recientemente.
Desinstala tu driver usb cdc completamente (borrándolo del pc) e instálalo de nuevo... seguro que es ése el problema
Re: PIC-Tengu
« Respuesta #265 en: 21 de Julio de 2011, 18:40:01 »
Hola mulinee,
jfmateos2 ya esta, ya he conseguido hacer que vaya.. fue un error mio al grabar el programa al PIC (con winpic800).
ahora solo me falta una cosa.. y es de circuitería..
en teoría si soplo/chillo fuerte, tendría que despertarse, cambiar de cara, y apagarse las velas, pero no lo hace.. , comprobando el amplificador, descubrí que si conmutaba las patas 7 y 8 con un pulsador, si que podía hacer ese efecto.. pero creo que no debería ir así.. se te ocurre alguna idea? no se si me he explicado bien..
edito: He leido que hay gente que dice lo siguiente:
"Los microfono de Elect, necesiatan una corriente Fantom, y 5 Volt es muy poco, asi que usa una bateria de 9Volt o mas"
« Última modificación: 21 de Julio de 2011, 18:43:49 por mulinee..46 »
Re: PIC-Tengu
« Respuesta #266 en: 22 de Julio de 2011, 11:16:00 »
No sé qué decirte mulinee..
El comportamiento normal es que si le soplas se despierte y comience el juego de las velas, como se ve en el vídeo... aunque sólo la primera vez que se enciende... la veces siguientes ya no sale el juego de las velas.
Re: PIC-Tengu
« Respuesta #267 en: 08 de Marzo de 2014, 06:51:05 »
He visto esto y me recordó a tu PIC-tengu
Desconectado gera
Re: PIC-Tengu
« Respuesta #268 en: 08 de Marzo de 2014, 12:20:11 »
Es buenisimo!!! No sabia que venian componentes tan pequeños (matriz de leds y arduino).
Ver estas cosas me hacen dar mas ganas de tener una impresora 3D jaja.
Re: PIC-Tengu
« Respuesta #269 en: 08 de Marzo de 2014, 13:53:07 »
Mola, pero no es sensible al sonido...¡y eso sí que mola  :mrgreen:!
